| | | Forums66 Topics128,281 Posts1,058,479 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 25 Apprentice | | Apprentice Joined: Mar 2009 Posts: 25 | I have a 1966 Chevy C10,4:11 rear. I need a speedometer gear housing,that uses 40 to 45 driven gears.
Anyone know where I can buy the speedometer gear housing?
Or if you a running a MY6,with 4:11 rear end.What did you do,so your speedometer would show to correct speed?
Jimmy | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The gears are available on ebay. IIRC I bought both my rebuild kit and speedo gear from the same seller. I told him my rear axle and tire size, he shipped a gear. Unfortunately other projects have kept me from installing it.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I did this exact deal on my '62 Suburban (and wrote a story on that transmission for Custom Classic Truck a year or two ago).
It's the same drive gear and housing as a 700R4 or TH350.
Speedometer World (888) 877-1008 Central time, open until 5pm.
They had them at reasonable prices (especially compared to the local Chevy dealer). They have a calculator on their website that tells you what drive gear you need based on tire height and rear end ratio. I've got 3.42 gears, 29-inch tall tires, and a 40-45 housing. I needed a 43-tooth drive gear.
Now, my speedo MPH is off, but my odometer is accurate almost to the foot, according to GPS and highway mile markers that were spaced every 1/10th mile. My speedo needs to be recalibrated, rather than the gear needing to be redone.
Hope this helps. -Brad by the way--the best $100 you can spend is to have the original Hurst shifter sent back to Hurst for a rebuild. Maaaan you won't believe how nice it is! Also, if you need a new tailshaft housing seal or trans yoke, it's also the same as TH350.
SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | |
