10 members (Lightholder's Dad, gswbbc, FAST55, 48jim1ton, frogfarmer, Gdads51, tclederman, Ponchogl, 68ironhead, 1 invisible),
135
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Simple as that; can a GMC postive ground, and Chev negative ground starter be interchanged? Does anything need to be wired differently if so?
I have a lead on a cheap Chevy starter nearby, to go in my '49 GMC. Thanks in advance! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | No, they are not, because of the DC voltage they are wired reversed of each other, one would run clockwise and the other would run anticlockwise thats how You change direction on a DC motor.The Chevy starter would turn Your engine over in the wrong direction.
Pete
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | That's an "old mechanic's tale", sort of like an "old wives' tale". Anytime you can make a starter with field coils, (not permanent magnets like the modern ones) run backwards by simply reversing the polarity, I'll kiss your butt at high noon on any town square you name, and give you an hour to draw a crowd. The field windings prevent that from happening. A power window motor runs both ways by simply swapping positive and negative, but the field magnetism is provided by permanent magnets that can't reverse their poles. Not so with wire-wound field coils! The starter will run the same direction regardless of which battery post is connected to ground. Generators are ground-sensitive, not starters, but simply re-polarizing a generator makes it compatible with either ground polarity. Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If the above ain't enough, look at the Hollander. GMC and Chev starters are both a 436 in the 32nd Hollander. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I always thought that all DC motors were that way , i did look it up in one of My motor books and of course Hotrod is right. The above is more than enough.
Pete
| | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Thanks a lot guys! Not sure yet if I'll need the starter, mine seems perfectly fine, but it shorts everytime I give it power. Very good to know though, thanks muchly! | | |
