| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59921 05/01/2006 5:02 PM | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | All, I am looking for steering gear lube and a rebuild kit for my '42 steering box. I've learned the hard way that 90 weight oil just runs out the steering shaft! I found a post by Jim Forbes who listed a GM #1052182 but this lube was discontinued in April of 2002. What is the alternative I can use? Anyone seen an ad in Hemmings possibly for the lube? Thanks in advance!
Bryan Bauman
#59922 05/01/2006 6:16 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Try a search here, there have been several postings on this topic in the past 6 months reccomending a combo of gear lube and heavy oil or tractor lube.
#59923 05/01/2006 9:47 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I usually pump it full of chassis grease & add a little gear oil. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#59924 05/01/2006 10:27 PM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Try using John Deer Corn Head grease, AN102562.
Chev's of the 40's has rebuild kits.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
#59925 05/02/2006 2:16 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The kits include the upper and lower bearing and race, the side cover seal, the sector shaft seal, ball bearings and a bushing for the sector housing.
After discovering the bushing was too long I cut it down and then ID of the new bushing was too small so I honed it out with a brake cylinder hone.
Before you buy a kit you could check with NAPA and tear the box apart to see where the problem is.
You can get the bushings, bearings, seals and the adjusting screw at NAPA for the 47-53 trucks for sure. I'm not sure about the ballbearings, but I'd bet they are a standard size. Often the NAPA guys can work off the numbers stamped into the old parts so I pull them and take them in to NAPA and say "I need one of these", they punch it into the computer for a cross over number. If not maybe someone here can hook you up with them for your '42.
#59926 05/02/2006 3:14 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Use a moly base gear lube. It stays soft at lower temps than lithium.
Fred 52 3600 69 C-10
#59927 05/02/2006 4:41 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Nearly all the ford suppliers (Mac's, Carpenter, etc.) offer 400 weight lube. On second thought model A sites might be better. I agree with others that a modern lube has a lot better performance but it gives you an option.
Evan
#59928 05/02/2006 9:03 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | PENRITE STEERING GEAR LUBE | | |
#59929 05/02/2006 11:41 AM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Over here Castrol market a semi-liquid grease with extreme-pressure additives,originally developed for sealed bulldozer track-rollers,low speed gearboxes etc. It's fluid enough to flow back to the bottom of the steering box but thick enough not to leak- should be ideal. It's sold here as Castrol TC Grease | | |
#59930 05/02/2006 11:50 AM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | JD cornhead grease is the way you want to go..must be more than 1 farmer on this site...hehehe...doc | | |
#59931 05/02/2006 1:18 PM | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | Thanks for all the replys! I plan on finding the John Deere, Castrol or the Penrite lube. Then contacting Chevs of the 40's as well as Napa for a rebuild kit for the box. I understand the "newer" steering boxes, 47 to 54 are a better design, any thoughts there? Is it worth finding one to use instead of mine, once it is rebuilt?
Best Regards, Bryan
Bryan Bauman
#59932 05/03/2006 4:41 PM | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Bryan,
The later boxes mount very different than the 41 - 46. Get the penrite lube. It is a direct replacement for the original lube used in these boxes. It will take hours to pour into the box. It is very thick. The 42 - 46 steering box is the best box for your truck if you want a bolt in, original type solution. | | |
