| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | I am now trying to find a pair of metal motor perches that mount to the frame and the rubber mount on the engine is there a dealer for this part??????????????? they look like v8 mounts only the drivers side is shaped differently for six cylinder 63-69 motors???? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you want the ones for a 292 eng then ron | | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | yes a supplier for the perches towers brackets that mount to the frame and the rubber engine mount.............. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | these are for older frames than I have my frame is a 60 chevy sb apache. and I need the perches from a 63 6 cylinder motor. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | I could use the same info of a 61 283 3/4 ton. i just need to remount the engine from front to side so I can install a 700R4. I can make em but if I could get something close and modify it that would be great | | |
