9 members (Tronman, TUTS 59, cmayna, Otto Skorzeny, UnclePaddy, Steelonsteel, Peggy M, 2 invisible), 78 guests, and 3 robots.
Topics128,042
Posts1,055,505
Members48,424
#598978 12/07/2009 3:20 PM
Apprentice
Apprentice
I am now trying to find a pair of metal motor perches that mount to the frame and the rubber mount on the engine is there a dealer for this part??????????????? they look like v8 mounts only the drivers side is shaped differently for six cylinder 63-69 motors????
sdsmooth #598992 12/07/2009 3:58 PM
you want the ones for a 292 eng then
ron
padresag #598999 12/07/2009 4:12 PM
Apprentice
Apprentice
yes a supplier for the perches towers brackets that mount to the frame and the rubber engine mount..............
sdsmooth #599001 12/07/2009 4:23 PM
Drew
DrewP #599110 12/07/2009 11:00 PM
Apprentice
Apprentice
these are for older frames than I have my frame is a 60 chevy sb apache. and I need the perches from a 63 6 cylinder motor.
sdsmooth #599111 12/07/2009 11:00 PM
this link should explain it all for you
http://www.persh.org/pickup/perches.htm
ron
padresag #599148 12/08/2009 12:49 AM
I could use the same info of a 61 283 3/4 ton. i just need to remount the engine from front to side so I can install a 700R4. I can make em but if I could get something close and modify it that would be great
