5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#589364 11/03/2009 5:53 PM
I Have a 62 c10 that i want to replace the 6 cyl with a 454.Does anyone know if the bellhousing and clutch will bolt up to it and what kind of motor mount towers can i use? Thanks
How do you plan on getting the exhaust around the torsion bars ?
Well I have a set of Blackjack headers I would like to use.
the bellhousing and clutch from a 235 wont work on any v8. a 63 up six or v8 bell and flywheel will bolt up but is set up for mechanical release. you can remove the whole torsion bar crossmember and install a coil spring front suspension. I had a 427 in a 63 when i was a kid.
im only 15 so i probably aint got much room to talk but i had a 402 in my 66 jus fine with some mounts i made myself and stock manifolds and alls i had had to do was cut a little tiny bit out of the cross member under the bellhousing. takeing the engine and tranny out at the same time was a [censored] tho. i had a 4speed with granny and had to take the top off and make a new gasket
oh and i had a clutch and flywheel and bellhousing off like a 283 that bolted right up because they are internally balanced ithink but the bellhousing bolted right up
Riding in the Passing Lane
The 66 is a different animal from the 62. With a 454 you will have to use a 454 flywheel as it is externally balanced.
1972 Chevy c10 Cheyenne Super
"you can remove the whole torsion bar crossmember and install a coil spring front suspension."
OK, can anybody elaborate on doing this in a '62? I've been looking for some info on this for a '62 3/4 ton, but haven't found much about how to do it and what to use.
"Gas money give out in Gurnee" Eddie from Christmas Vacation
1962 C20, currently "Yard Art", working to reverse that.
