| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59877 04/30/2006 9:06 AM | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | What is the diameter of 3/4 ton hubcaps?? My rims are 17" 8 lug and the rear hub sticks out 3.5" Is this going to work with 3/4 caps? Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#59878 05/01/2006 1:32 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you're talking about an AD, the hubcap sits inside of a 9" circle. Any 8 lug wheel that I have seen will work, but you have to put in your own clips. 8 lug wheel thread
Fred 52 3600 69 C-10
#59879 05/01/2006 10:24 AM | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Thanks Fred yes it is a AD. Clips are in the mail is five per rim good? Maxx
#59880 05/01/2006 2:50 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see: http://www.speedprint.com/Deves50/hubcapclips.php if you need to fit the caps on something different
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
