2 members (Cosmo, Wayne67vert),
43
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59718 04/27/2006 3:20 AM | Joined: Aug 2003 Posts: 33 Junior Member | | Junior Member Joined: Aug 2003 Posts: 33 | I have been running a 4 on the floor( granny low) for the last 23 years in my 50 Chevy. From the factory she was sporting the 3 on the tree. Broke two of them and switched to the 4 speed. I just found a 3 speed with overdrive and plan on installing it in the next month. I saved all the old linkage and the mixer,or shift box. My question is what is there to rebuild the mixer. I tore mine apart, nothing but a spring inside besides old grease, Is the rebuild the new bellow on the ends of the shaft? Or is this one missing parts? Am also going to open drive line 373 gears out of a 67 Chevy 1/2 ton.Is there a picture of the linkage setup somewhere. Dave
Stock and loveing it.
#59719 04/27/2006 4:36 AM | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | Dave-- Have you considered just usin a 3sp with a floor shifter--I've got the tranny you describe and it works fine.
Taco
#59720 04/27/2006 10:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The selector box is easy to o-haul. If the levers are worn & grooved you can build them up with weld & grind & file it down. They work slick when they are right & are very nastalgic. It,s surprizing how many people can,t drive them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
