| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | I have got a 52 216 engine that i am replacing with a 55 261 engine reuseing the original 3 speed can anybody tell me if the clutch and flywheel are the same? The 261 had a four speed trans.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If it is a first series 55 261 you can use the 216 bellhousing, flywheel, and clutch and it should bolt up.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You should be able to use your 216 clutch assembly (pressure plate, disc, and throwout bearing) and 216 flywheel in your 216 clutch-housing with any year 261 engine. Make sure the pilot bushing is in good shape and that it matches the transmission.
Will you be staying with the original 6v foot-pedal starter?
What year transmission will you be using?
| | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | I will be replacing the pilot bushing and will make sure its correct. And yes I will be staying with the original foot pedal starter.Thanks for the info. Greg | | |
