7 members (farmallb, Samantha, Opelika Tom, Oswald, Hanks custodian, 2 invisible), 79 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#597030 12/01/2009 12:49 AM
Apprentice
Apprentice
I have got a 52 216 engine that i am replacing with a 55 261 engine reuseing the original 3 speed can anybody tell me if the clutch and flywheel are the same? The 261 had a four speed trans.
If it is a first series 55 261 you can use the 216 bellhousing, flywheel, and clutch and it should bolt up.
Drew
You should be able to use your 216 clutch assembly (pressure plate, disc, and throwout bearing) and 216 flywheel in your 216 clutch-housing with any year 261 engine. Make sure the pilot bushing is in good shape and that it matches the transmission.
Will you be staying with the original 6v foot-pedal starter?
What year transmission will you be using?
Apprentice
Apprentice
I will be replacing the pilot bushing and will make sure its correct. And yes I will be staying with the original foot pedal starter.Thanks for the info. Greg
