Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (GMCJammer51), 92 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#580915 10/06/2009 8:13 AM
whats all needed/ involved in putting HEI dist. in my 65 c20. It has a 250 from a 76-79 car?? ( integral intake manifold)
how much does it cost, i will do all the work myself.
and where do i get it?
trevota #580926 10/06/2009 12:39 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Get a HEI dist, w/all the guts and a dist cap w/the coil which will go in the top of the cap along w/the plug wires. To install is just like replacing the stock point dist. THIS VIDEO should help you even though it is for a V8 w/installing. Cost?? You can find them they on ebay using "chevy 6 distributor" in the search BUT be sure NOT to get a 2.8 or 4.3 V6 dist. they will NOT work, or at your local boneyard or parts house. THIS site may help you.
#581081 10/06/2009 8:53 PM
Apprentice
Apprentice
Used HEI distributor $30.00 to $50.00 from ebay.Coils that are in the cap cost a little bit more.
Jimmy
trevota #581195 10/07/2009 3:12 AM
trevota #596204 11/27/2009 11:43 PM
Make sure you remove the resistor wire for your old coil. with nowhere to go the power can make that wire melt along with all the wires around it and maybe your truck.
