| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Please advise what headers you have used in Task Force trucks that fit Chevy V8 small block, inside frame and clear stock steering box. Brand and application. thanks
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have a 283 in my Task Force, I am using original cast iron Corvette headers. They fit fine - no clearance issues, I decided against tube headers because a number of people said they tend to warp and leak after a while. I don't know if that is true, but these headers are also useful because they have the mounting for the alternator/generator bracket. They show up on eBay on a fairly regular basis if you have an interest in them. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used the Headman blockhugger headers on my 55,they work just fine. | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | I have the same as Dale937 - Headman blockhuggers.
Look and work fine. (55 2nd series) | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | For full length headers, the Hedman 68276 work pretty well. They're for a first generation camaro. Here's how they look with an aftermarket steering box. There's no issue at all on the other side, there's a ton of room http://picasaweb.google.com/ChrisAurit/PhotoHistory#5407788443454507842 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | | quirt111 Unregistered | | quirt111 Unregistered | Do your corvette stock headers clear your power steering pump? Is it a power steering box or manual? | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Just like most of the guys on this post I went with Block Huggers.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | My steering is manual, I wish I had power steering though. Sounds like to me that warping or leaking after-market headers is probably not generally true, or depends on the quality of the headers possibly. Everyone here seems to have positive experiences with their headers. | | |
