5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
Sir Searchalot
Sir Searchalot
Please advise what headers you have used in Task Force trucks that fit Chevy V8 small block, inside frame and clear stock steering box. Brand and application. thanks
I have a 283 in my Task Force, I am using original cast iron Corvette headers. They fit fine - no clearance issues, I decided against tube headers because a number of people said they tend to warp and leak after a while. I don't know if that is true, but these headers are also useful because they have the mounting for the alternator/generator bracket. They show up on eBay on a fairly regular basis if you have an interest in them.
I used the Headman blockhugger headers on my 55,they work just fine.
1 Offline
I have the same as Dale937 - Headman blockhuggers.
Look and work fine. (55 2nd series)
For full length headers, the Hedman 68276 work pretty well. They're for a first generation camaro. Here's how they look with an aftermarket steering box. There's no issue at all on the other side, there's a ton of room
http://picasaweb.google.com/ChrisAurit/PhotoHistory#5407788443454507842
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
Sir Searchalot
Sir Searchalot
thank you very much.
i have hooker block huggers on my 57, with a 350 sbc and th350 auto.
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01336.jpg
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01337.jpg
they work really good on mine, since it is lowered. i dont think i could use full length headers on mine.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Q
quirt111
Unregistered
quirt111
Unregistered
Q
Do your corvette stock headers clear your power steering pump? Is it a power steering box or manual?
Just like most of the guys on this post I went with Block Huggers.
38 original
48 panel
59 stepside
46 in the back forty
My steering is manual, I wish I had power steering though. Sounds like to me that warping or leaking after-market headers is probably not generally true, or depends on the quality of the headers possibly. Everyone here seems to have positive experiences with their headers.
