6 members (55shaker, MickeyP, Shaffer's1950, Ranger, KCMongo, Otto Skorzeny), 74 guests, and 0 robots.
Topics128,051
Posts1,055,705
#594406 11/21/2009 11:06 PM
I changed my alternator from an external regulator to an internal regulator, and now the engine runs on for about a minute after I turn the key off. it did not do this before I changed alternators
Truck is a 38 gmc with new drive train and Rebel wiring kit, I wired the alter. exactly the way rebel said to. so whats going on that it keeps running on after the key is turned off. I know it is some thing simple
thanks
1938 Gmc 1/2 ton
TheShoer,
Your new internally regulated alternator has a DA plug. The terminals are marked #1 and #2. The terminal marked #1 needs to be energized as you start your rig to make the alternator begin to charge.
After your engine starts, this terminal actual begins to produce voltage. If you have wired this circuit in series with the coil in any way, and the circuit isn't broken when you turn the key OFF, the alternator will supply enough voltage to keep the ignition circuit charged and the engine will keep running.
If you have wired #1 to the coil, as is often done, you will need to install a small diode the will prevent voltage from flowing to the ignition and causing this problem. Many alternator swap kits contain a DA plug that has a small diode installed in the line near the plug.
Stuart
Jim Carter sells this
DA plug for alternators
part # HP240
It has the diode installed in line with the plug and long wire .
Pete
Thank you when I first read what you wrote Stuart I was confused, then after I thought about it for a while it hit me like a ton of bricks and made perfect sense. I was going to ask If the local parts house would carry something like that and what it was called then Pete answered my question before I could ask, Thanks Pete.
1938 Gmc 1/2 ton
I bought my diode at radio shack and soldered it in the wire.Be sure to install it correctly,the electricity only flows one direction.
1951 3100 Chevrolet
Bowtie what kind of diode would I ask for at radio shack or do you have a parts# I can ask for. The radio shack route would save me some money. Which way does the electric flow in this application from #1 or to #1
1938 Gmc 1/2 ton
TheShoer #594932 11/23/2009 7:52 PM
sorry double tap
1938 Gmc 1/2 ton
I found the radio shack part number here on the stovebolt.I will go out in the garage and see if i have the part#.I checked my diode with a ohm meter to see the direction of flow.
1951 3100 Chevrolet
Here is a link to the information.You will see a radio shack link by automark.Hope this helps,good luck.
radio shack diode
1951 3100 Chevrolet
thanks that helps and confuses me at the same time. I'll get the diode tomorrow
1938 Gmc 1/2 ton
there's the symbol and the markings for diodes here:
http://www.kpsec.freeuk.com/images/diocon.gif
The Cathode end on the symbol is the one with the bar across the line. This will usually be marked on the diodes you buy with something like a colored band.
The positive current will only flow in the direction Anode to Cathode, so you want the colored (Cathode) end of your diode pointing towards your alternator connection to stop the motor running on.
No harm done if you put the diode in the wrong way round first time, it's just that your alternator probably won't charge; if it does, the motor will still run on.
Stuart.
