| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | I have just rebuilt my 235 and 4 speed trans for my 53. I'm ready to put them back together and have a question. I'm wondering if anyone can give me the proper way to install the flywheel and get the nessesary torque specifications. Nothing im my manuel brakes this down. Any help would be appreciated. Thx
Kent 1953 1/2 ton Chevrolet
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well it would have helped you to mark the flywheel position on the crankshaft dowels for easy line up. If you didn't you'll have to set the engine at TDC and align the flywheel by the timing marks on it.Use the "X". The torque spec is 55-65 foot pounds.
Drew
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The flywheel will only go on one way.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kent,
It's pretty simple to jam the flywheel using the ring gear and some type of screwdriver or wedge. This prevents it from turning as you attack it with your torque wrench.
The trick is to sacrifice a 6 point socket for the job! Because the bolts that hold the flywheel to the crank have shallow heads it's easy to round the corners off as you try to tighten them. If you take the appropriate size socket and grind it dead flat on its end the likelihood of it slipping off the shallow bolt heads is much less.
I would torque in two steps to the final value using a logical torque sequence. Make sure the mating flanges and spotless when you mount the flywheel.
I don't know if they use locking tabs or Loctite (blue) these days...I remember locking tabs.
Stuart | | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Stuart thanks for the information this is where I was having difficulties. I appreciate the time end effort, I'll give it a shot.. Thanks again, Kent
Stuart [/quote]
| | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Thanks for the info Drew.. ]
