1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#593694 11/19/2009 2:41 AM
Guys, I'm a 20 yr veteran of a fully restored 1/2 ton AD truck, and know where all the parts can be found. I'm thrilled to say I'm starting a restoration on a 1 ton GMC, and have at least one question...
I know the brake cylinders for a 1/2 ton are readily availavble (NAPA, ETC). Will I have the same luck with brake cylinders for my one ton? Are they the same, or are the 1 ton's beefed up?
Thanks!
Dennis
Hey Dennis,
I'm assuming you have a AD truck? If so I bought all new cylinders from here . I purchased all four wheel cylinders and a master cylinder.
Bruce
My Trucks
Stuff I Collect
The 1-ton stuff will be different.
I'd start with your favorite supplier and then extend your search until you've found everything.
I've seen 1-ton brake parts listed various places, but have yet to buy any myself. That comes of being a hot-rodder and always deciding to modify instead of restore...
OldSub #593748 11/19/2009 5:23 AM
Former Workshop Owner
I just went through this with my '59 Viking 40 (1 1/2 ton). I wanted just the wheel cylinder kits, and bought two sets that wouldn't work. The first set came from a well known antique parts supplier, and the other set came from NAPA. It turned out that, both sets were for the original wheel cylinders that came with the truck from the factory. The problem is that the originals had long ago been replaced with after market ones. Although they (the after market cylinders) might work the same, the inside parts were vastly different.
I finally found the parts I needed by calling a shop that specializes in relining shoes, and clutch discs. This guy new exactly what I needed, and had the right parts for me the next day. He was even less expensive than the other suppliers.
The worse part, is I wasted several nice weather weekends with the wrong parts.
You will probably want to look for someone in your area, but I found the correct parts at "Auto Brake & Clutch" in Omaha, NE.
Good Luck
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Moderated by  Dusty53
