| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | My '51 1/2 ton is stock (if you consider a 235, 53 4-speed tranny and 47 rear end stock). On connecting universal, driveshaft was off about 3/8" from tranny. I forced them together, drove about 300 miles and dismantled. No apparent damage to universal, but I get vibration decelerating. Is there any way to better align the drivetrain? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You might want to check your locating pins for your rear end where they meet the leaf springs. Sounds like your rear end is off. | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | But what can you change or adjust to bring it into alignment? Everything has been apart, the springs re-tensioned, etc. I can see something's off, just can't figure out what to do about it. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Assuming you didn't have this problem before? I dont see how a torque tube drive train can be out of alignment, 3/8" isn't much when you consider the distance from the rear axle to tranny. A little slop in the rear spring bushings, and worn motor mounts could change your alignment quite a bit. Hang in there and one of the wiser bolters will come up with an answer. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What direction is the misalignment in? If left to right I'd say it's just the axle pivots/bushings doing their own thing but differently because the torque tube is disconnected, as soon as you push it over and reconnect it there is no problem. But that wouldn't cause a vibration?
Grigg | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | Oh, and there's one other, kind of weird symptom. The rear cap of the bell over the universal won't stay on. I've tightened it with a pipe wrench and, in a couple of miles, it's off. And that's a lot of fine threads. Of course, it leaks. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You might want to find someone with a parts book and look up some numbers.
The running gear on '47 Advance Design trucks carried over some earlier designs, and I'm wondering if your '47 rear axle might be a little different than a '48 or later truck.
I don't know if that's the problem, but since the transmissions are a lot different it is reasonable other pieces are too.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From an old article about Advance-Design trucks: . . . In 1948 Chevrolet was the first of the volume manufactures to offer a 4-speed synchro-mesh, helical gear transmission as regular equipment. It was an extra cost option. As a result of this complete redesign, the 4-speed transmission case was wider, higher, and longer. It was still of the same rigid, box-like cast iron construction as before. So that the new 4-speed transmission could be mounted interchangeably with the 3-speed transmission it was necessary to increase the length of the 3-speed transmission case and main shaft. . . . Here's a diagram of the rear-axle, for part numbers.It looks like the torque-tube changed in '48. Tim | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I feel like I want to apologize for being right. It looks like you need to change some parts...
I know a guy near Rochester NY who is hot rodding a '50. He'll be removing the parts you need soon. I suspect with a little hunting around you'll find someone like him who will practically give away the parts you need.
