hey guys, putting my 261 back together after rebuild. i had to put a different crank in it because someone had welded the nose of old one. harmanic balancer will not go on, seems like new crank snout is a tad larger. my question is did they have different sized balancers for dif. years. i know the machine shop got a used crank and turned it so year might be dif. thanks for input.
