3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#591015 11/09/2009 4:04 PM
What year(s) were Chevy trucks equipped with 16"x6", six-lug wheels? Do these wheels have the old-school clips for hubcaps? Any problems with backspace or other issues if I mount these on a '49 1/2-ton? I want a wheel that will accept 215/85/16 radials and the original '49 hubcaps.
norcal49er #593187 11/17/2009 6:26 AM
Dead silence, so let me rephrase the question... How wide are the 16-inch, six- lug stock wheels on late 50's and early 60's Chevys? I want to install 215x85x16 tires, so I'm looking for a donor truck with 5.5 to 6-inch wide wheels. I'd also like to use my original '49 hubcaps if that's possible. Hubcaps have an 8-inch inside diameter. Thanks.
norcal49er #593192 11/17/2009 7:07 AM
they're 5.5 and 6", and up to '60 they have the clips to take the caps, 3 clips rather than the earlier 6, but should work
Flxible #593275 11/17/2009 6:35 PM
My 54 came with 2-15x6 wheels they have 6 clips and are stamped KH 1957. They look just like the 54 originals.
Lonnie Gallaher #593392 11/18/2009 3:40 AM
Thank you. Any idea what year the stock 16-inch, 6-lug wheels went from 5.5 to 6.0 inches wide? And what year did they go from 6 clips to 3 clips?
norcal49er #593403 11/18/2009 3:57 AM
3 clips started by 55.2 at least and went until 60 when they quit using them, any earlier I've seen were 6, but later wheels still have the holes for mounting the clips and some of the vendors carry the clips .... most 55-59 wheels I've seen are 5 1/2" but I have seen some 6"
Flxible #593418 11/18/2009 4:36 AM
Just as an FYI, wheel vintiques sells an original 47-53 hubcap that will install without the clips.
