3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
hi,
i have a radiator that i would like to limp along for a few more months. the po sealed up a leak where the upper tank meets the core with jb weld. it leaks now and i'd like to remove the jb weld and braze the leak shut. there is a seam of jb weld about 4" long that i dont know how to remove. any suggestions on how to remove it?
i guess i should google before i post. it says on the jb weld website it can only be removed by grinding or filling or heating above 600 degrees. that sounds like an awfull mess. maybe adding more jb will get me by for awhile.
Use a dremel with a carbide reamer bit. Cuts through JB very well.
1951 Chevy 3100
"Project for my Wife" - Jigsaw Puzzle
1969 Camaro SS350 convertible
1969 Camaro 327 convertible
small pencil torch and a pick
i have both a small torch for my o/a set-up and a dremel. i'll try a combination of both. thanks.
carefull with that torch eugene, or you'll melt a whole lotta solder joints that you really don't want to
JB Weld is a form of epoxy and softens/melts with heat. Ditto Scott above. If you can get to it afterward, use a twisted wire wheel to clean up before brazing. Epoxy can also be cleaned, while in soft/liquid state, with acetone or white vinegar so maybe while still warm, after removal of the majority, wipe it down with one of those.
Dave.
What's the last thing a red neck says, "Hey guys watch this."
What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
thanks for the suggestions. i used the torch to get the majority of it off and then the carbide dremel bit to get inbetween the fins. both worked well.
i'll try some acetone or vinigar to prep before brazing.
