2 members (2-Ton, Gdads51), 107 guests, and 2 robots.
Topics128,093
Posts1,056,475
Members48,444
#591800 11/12/2009 4:04 AM
Apprentice
Apprentice
OK I've read the shop manual and searched the forums here and found plenty of discussion about wheel bearings but not the answer to my question. I'm replacing the front wheel bearings on my 1/2 Ton 57 Chevy 3200, found the replacements at Golden State Parts. When I was removing the spindle side inner race, it's a three part ball type, it found that it spins freely on the spindle. Not too free but not a press fit and stationary as I would have expected it to be. I've replaced many bearings on many things, but not this type. I don't believe the races should spin. Am I wrong in this case?
Mine did the same thing. don't worry about it, it's normal for the ball bearing style. Once the preload is set, they'll be fine.
Bill Burmeister
Apprentice
Apprentice
Thanks for the response, it was the same on both sides so I thought it was probably just the way it is, but I like to be sure.
Riding in the Passing Lane
That's normal.
1972 Chevy c10 Cheyenne Super
I am going through the same situation and after measuring found one side to have about .002" wear and the otherside .004" wear on the spindle lower surface for the inner bearing. I have found other used spindles and found the same type of wear. Any ideas what type of wear would necessitate replacing the spindle?
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
blanch53,
I think what you are describing is differences if fit, not "wear". Normally those surfaces do not have movement between them and wear doesn't occur. With the bearing installed and torqued, there is no movement there.
1951 1 Ton Completed
Hey truckernix
you make a good point, there should be no movement between the inner race and the spindle. Unfortunately my newly acquired truck had no preload for the wheel bearings and may allowed the bearings to spin on the spindle. I have been told by a local expert not to worry until the worn groove created by a spinning bearing reached .020 or more. I am not keen on seeing any groove on a shaft created by a spinning bearing. I have heard of a sleeve being pressed on to a hard to find spindle to bring it back to a standard size. This maybe an option I might pursue.
