0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59112 04/12/2006 3:06 AM | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | what do the bolters think?
283, maybe original.. | | |
#59113 04/12/2006 3:18 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | If it clears the firewall I would do it.
If you want it to look original, you can do a pertronix kit in about 15 minutes. | | |
#59114 04/12/2006 3:28 AM | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | i'm not overly worried about original in every aspect.. my old truck looks close enough to most..
I haven't done any research yet, but assume that one just hooks a switched hot to the hot side, and gets rid of the coil, etc..
btw, the firewall check is a good idea, i have an old one and will check that.. | | |
#59115 04/12/2006 3:34 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the HEI will fit, at least some trucks, but it's really tight - tried it on my 58 and it was touching the firewall, so I skipped it [tough to get back out w/ the engine in place!!] - might have been ok w/ shimming up the rear mounts a quarter, but I'm useta changing points, so don't care
Bill | | |
#59116 04/12/2006 3:39 AM | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | mines a '58 as well... i'll do a test run with an old one out of the vette and post the results..
may be a week or so.. | | |
#59117 04/12/2006 3:42 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Nothing a 2 pound hammer can't fix. | | |
#59118 04/12/2006 3:46 AM | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | i'm too lazy to swing that kind of shet...  | | |
#59119 04/12/2006 4:04 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I'll second the above, faster starting, hotter spark, no points. That said you may not get the performance you expect. Seems that starting in about 1968 (points) distributors started losing centrifugal advance and vacuum advance. As an example 63 292 six distributor is 0@600, 14@1500, 28@3700, vac adv 6@4-7 pounds, 23@13-14 pounds a 1976 distributor is 0@1100, 6@2000, 14@2300, 24@4100, vac adv 0@10-12 pounds, 10@13-14 pounds. The distributor can be recurved to get back what you lose. I need copies of the distributor data in a few more shop manuals for a better understanding of how far it goes. I would have the HEI recurved to the 58 distributor. If your compression, cam, carb have been changed then the curve needs changed or live with it. Larry
I don't own a vehicle that isn't old enough to drink. | | |
#59120 04/12/2006 4:08 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | I agree with the recurve. A distributor recurve kit with an adjustable vacuum advance canister ought to be on everyone's tune up list. | | |
#59121 04/12/2006 12:44 PM | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Originally posted by 4.3in84toy: I agree with the recurve. A distributor recurve kit with an adjustable vacuum advance canister ought to be on everyone's tune up list. recurve and do total advance..about 12 to 16 on the base, 16 vacuume, and 20 mechanical have that on my vette. Accell billit. I think it was only about $150 or $175... | | |
#59122 04/12/2006 10:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Crane has a conversion kit for the window type dist. that is real neat & simple to insall. I like it better than the petronics for that dist. I get them from Summit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
