| | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | Howdy, I've got a 54 i/2 ton with a hacked up frame and I'm looking to do a swap. I found a 52 frame for a good deal. Only thing is it from a 52 1/2 ton GMC sububan. Can anyone give me a hint?? Thanks | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The frames are totally different. The change occurred in the 1954 bed. Use the search feature, lot's of info on this subject. old topic I have seen some 54 frames on craigslist in your area, pm me. (just checked..none available) Place an ad in the swap meet section! | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | deant54, Look for a 54 Chevy 1/2 ton frame, they are out there. Several years ago I needed one for my 54 3100 (mine was very badly rusted), and found one from a Bolter here. The frame was in Oklahoma, the price was good, and I found someone that would bring it to northern Florida very reasonably, where I was able to pick it up. You'll have a lot less problems and it will be an easy swap, since the 54 1/2 ton frames are different from the earlier AD 1/2 ton frames. Samantha | | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | Thanks Samantha, I posted on parts wanted today so we''ll see how that goes. so is there a differance in the rails? Cutting and fabbing is no biggie, my rails are just shot. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The biggest difference is in the kickup over the rear axle. The '52 has enough more kickup that you have to raise the '54 bed to get it to fit the frame.
I've seen this swap done and it just looks wrong when finished.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | Thanks old sub,thats about the only real differance I saw. What i didn't say first was that I'm planning on putting a 88 corvette rear init. So that extra hump will come in handie. Thanks | | |
