| | | Forums66 Topics128,169 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, I want to learn something about this carburetors. Which is better,advantages from each other, why I think the rochester is more popular, etc. Thanks, Alfonso
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Rochester was by far the most popular, because they were cheap. Carter is a more complex carburetor, but I personally prefer a Carter over a Rochester. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What type carb are we refering to? 1 barrel, 2 barrel, 4 barrel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Alfonso, I personally love the basic simplicity of a well built Rochester. But, a lot of alternate opinions and interesting information can be found in the forum archives. For an example of a recent and very well informed discussion try this | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, I´m talking about the 1 barrel carb works in my 1952 chevy truck thanks again, Alfonso | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | History:
In 1923, Carter and Chevrolet entered into a contract that called for Carter to supply carburetors, and allowed Chevrolet to also build Carter carburetors in the Bay City plant. It is well documented about the "C" on a Carter casting being a Chevrolet-built Carter.
In 1949, Rochester Products Division issued their first carburetor of their own design (on the 1949 Oldsmobile). This was the type "AA". It was quite common for carburetor manufacturers to begin their models with the letter "A", and double letters models for two-barrel units. Hence the AA was a two-barrel carburetor. This unit, with modifications, was continued into the 1950 model year.
In 1950, RPD released the model B (single barrel) for use on Chevrolet, incensing the management at Carter.
In 1951, RPD released a two barrel version of the model B for use on Cadillac.
In 1950, Carter management put on a push to develop a much superior carburetor to the model B, and produce models that were a direct replacement on all Chevrolet 6 cylinder products. These were the model YF's.
Opinion:
The model AA was a terrible excuse for a carburetor, and was discontinued after only two years.
The model BB was as bad, and Cadillac used it only for a year. Cadillac also used Carter in 1951, and since 1974, we have sold only 2 kits for a model BB on a Cadillac. Very rare to find even a Cadillac owner today that knows that they existed. Virtually all were replaced by the Carter units.
Rochester then came out with the model G in both two-barrel and 4-barrel versions, which were wonderful carburetors.
We used to restore the Rochester B; but VERY labor intensive to straighten the warpage caused by utilizing only 4 screws from the airhorn to bowl. Could I make them work? Yes, but only for a few years and the warpage would return. The warpage causes an internal vacuum leak which causes the power valve to stay open and creates an overrich mixture.
So:
You will see more Rochesters, because they were original equipment.
Many, like myself, feel the Carter is a superior carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | As soon as I read your question, I was going to write about Rochester B's 4 screw design. I see Jon mentioned it already!
This is the reason I went to a Carter YF. I've been happier with the Carter because it has 7 screws and, to date, no problems at all with it after swapping out the Rochester.
Bill | | |
