| | | Forums66 Topics128,180 Posts1,057,165 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Has anyone tried to use the 55-1 hotchkiss rear axle and springs under a half ton early AD (47-53) truck? I know the frames and motor mounts are different but thought I would ask since it is a while before I can set up the truck for a hotchkiss (open) axle and driveline.  | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only difference in the springs is where the spring center bolt is located. It is back about 2" from 1954 and earlier to match the open drive style perch.
See the USA in your vintage Chevrolet! My Blog | | |
