| | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58859 04/07/2006 12:42 PM | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | My Dad had a 50 Chevy with a add on overdrive that went behind the trans, after shortening the tube. Has anyone heard of such a thing? Where might I get some info on it? He had removed it before trading off the Chev and stashed it away. I haven't found any name or tag on it yet. I think I have all the hard parts for it and the 4.11 rear that he had behind it. Thanks for any help. Raycr | | |
#58860 04/07/2006 1:04 PM | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | I have heard of this before but have no info about it. I would like to know more too. Maybe somebody else will jump in. Keep us informed if you learn more. Oh, btw, Welcome! :p
Professional Novice
#58861 04/07/2006 1:13 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I've seen that done before on a torque tube where they spliced in the overdrive right before the rear end. I think it was a borg warner o.d. Not the whole trans, just the o.d. section. They welded a small sprocket to each end where the drive shaft was cut and butted them together and wrapped roller chain around them. It left a small amount of play so the joint would not snap under torque. Looked pretty neat. I saw a short article on this in the book "How to Restore Your Chevy Pickup" (I think that was the book) There is a company in the midwest somewhere that does this conversion. I am just going by memory and may have missed a few details. I'm sure a lot of other bolters have this book and may have more to say about it. | | |
#58862 04/07/2006 1:45 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Gear Vendors says they can make a torque-tube overdrive unit. Hold your breath when you find out the price (over $3000, I bet). | | |
#58863 04/07/2006 4:55 PM | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | I saw a 41 Chevy car for sale once that supposedly had O.D. I did not look under there to see, or drive it. I know that Gear Vendors makes a over/under drive unit for the SM-420 but I don't know anything about a torque-tube application. And yes, what they sell is about $3K.
Professional Novice
#58864 04/07/2006 5:16 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Truckstell of Portland, Oregon made an overdrive for torque tube Chevies. You can do a search for it in the archives. | | |
#58865 04/07/2006 5:41 PM | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | Raycr Was that a 50 truck? Half-ton? Probably with torque-tube - but the front driveshaft of a 50 3/4-ton is t-tube, the back half open. I know, I got one. Tell us more.
Professional Novice
#58866 04/07/2006 5:53 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | Frank50 - just curious - is that 3/4 ton drive shaft the same overall length as one for a 1/2 ton or is it longer?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#58867 04/07/2006 6:26 PM | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | Both shafts together are longer than 1/2 ton. The front shaft has the ball/socket joint on the front where it hooks up to the trans. and has the carrier bearing at the other end. Past that is an open yoke for a conventional U-joint. There is a seal in there right ahead of the yoke. Mine leaks. The rear shaft is rather short with yokes on both ends. I searched the internet and found some info about the Truckstell OD - apparently available from about 40 - 48 in cars. Maybe someone knows more???
Professional Novice
#58868 04/08/2006 1:09 AM | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | The overdrive was in a sedan as I recall. The unit was spliced in just behind the trans and the ball went in front of it and it clamped onto the tube and moved with the tube. I had found some papers for it years ago but can't find them now. Thanks | | |
#58869 04/08/2006 1:12 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Probably a Truckstell OD. You are a lucky man. That´s what a lot of guys want. Kind of the "Holey Grail" of torquetubers  | | |
#58870 04/08/2006 3:04 PM | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | Can pictures be posted? I'll try to get some shots of the colection of parts I've found for this on here. If this OD was for a car will if fit the pick ups with the tube? | | |
#58871 04/12/2006 9:17 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The Truxtell O.D. was great, I saw several of them back in the '50's. A friend had one that in 2nd overdrive would do about 80 M.P.H. They bolt onto the back of the trans. where the torque tube fits, then has a back side the same as the trans. All you have to do is shorten the torque tube the same amount as the length of the unit, and bolt it on. It is shifted by another shift lever. If you have one keep it, they are extremely rare these days. | | |
