3 members (JW51, tesa, Ponchogl), 49 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#588093 10/30/2009 8:13 PM
I'm thinking about going ahead and changing from vacuum to electric wipers and have one concern. Most of the new motors I see at the vendors have modern looking control knobs and I am wanting to keep it looking original. Can I just swap the knobs from my original? Or should I look at the original electric motors like on Chevy Duty's site? Thanks for your advice!
58' 3200 235 3-speed/OD
you can use the original knob.who,s tooo know.Are you going to Sema show?.People said to me that's a nice ford pu.I say thank you but it's a 51 CHEVY.See my point.What pleases you do it ,It's your ride,what make you happy do it.happy cruising
dan-pa
Apprentice
Apprentice
Just a heads up, I bought a wiper motor from one vendor that was made in China, did not fit correctly, what a headache so I returned it and got a wiper motor for another vendor made in the USA, it fit like the original no headaches.
Get one from Newport Engineering. That's what I'm unsing, works great and fit very well. I opted for the delay switch option, which is nice to have. The stock knob worked fine, but I did have to make a bushing to make it fit tight. Brass tubing, sourced from the local hobby shop, worked very well for that. Either switch will also give you the option of adding a washer pump if you want, it was the extra wire to run it. I got mine from Patrick's.
Bill Burmeister
