| | | Forums66 Topics128,069 Posts1,055,884 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | In my quest to find better gearing for my '57 3800, I've located a rear axle from a '70 C30 that the owner claims to be an Eaton limited slip with 4.10 ratio. My first question is will this axle be a direct bolt-in for my '57? Next, I'm a little confused about what this axle really is. My limited knowledge of this tells me that an Eaton axle under a C30 would be an HO72. The info I've read about these says that the HO72 was never available with 4.10 gears. He's 4 hours away so I don't want to make the trip and find out it's soemthing that I can't use. Can anyoue out there provide some insight on this? I've asked him to e-mail some pix but don't have them yet. Thanks for any help you can provide.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Hi. I installed an Eaton HO72 with 4.10 gears and "No-Spin" in my 1949 Chevy 3600 3/4-ton. I understand the Eaton HO52 and HO72 are identical except that the HO72 also has a thrust bearing adjustment(?). I'm not familiar with the '57 trucks, but if it's an Eaton HO52/72, you should have no problem.
If nothing else, the "No-Spin" option on the Eaton rearend is worth the risk. All of the 4x4 guys on the '67 to '72 Chevy Trucks web site are looking for the "No Spin" opion.
Good Luck! Dan M. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd be tempted to just make the trip. Its going to be real hard to know the gear ratio short of checking it on the spot.
The HO numbers refer to the axle as a whole, and reflect the weight rating of the axles. The biggest difference between the two axles is the size of the brakes, followed by the standard gear ratios. The differentials easily swap.
The No-Spin is desirable, but may not be for your application.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As the others have noted, the Eaton parts will swap no problem. Before you make a 4 hour trip, though, see if the seller can give you the ID code off the center cection. That will tell you if it's a 4.10 or not. The codes for a 4.10 HO72 rear for 1970 are as follows, TIE, TIH, TJL, TLX, TLZ, TMR, TNZ, TRN. There is also a possibility that it might be a Spicer 70, which was also common in the 1 tons of that era, though that is more of a GMC application. Even if it is a Spicer, you could swap the entire rear if you wanted to get the gearing.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I made the trip and think I came out okay. Here's the truck that's being parted. http://67-72chevytrucks.com/vboard/showthread.php?t=364393I got the rear axle and the 9' stepside bed (minus fire equipment). The axle is a 4.10 Detroit locker and the truck only has 12,000 miles on it. I plan to put both the axle and bed on my '57 3800.
