6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
#585623 10/22/2009 9:09 PM
Riding in the Passing Lane
The engine in my latest 58 has only 2 freeze plugs on each side of the block. It has no casting numbers on the sides & the pad below the right head is blank. It has no balance weights on the harmonic balancer. Does anyone got an idea what it might be? George
1972 Chevy c10 Cheyenne Super
3B Offline
Hy Wrenchbender Ret., is there a block casting number above the bellhousing mounting surface?
3B #585757 10/23/2009 5:44 AM
No numbers by the distributor?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #585867 10/23/2009 5:27 PM
Is the dipstick on the drivers side or passenger side?
don stocker #585909 10/23/2009 8:46 PM
I'll look at those things tomorrow. Isn't there something about only 2 freezplugs on each side? like a 400 block or is it the other way around. George
the early 400 small blocks had 3 frost plugs, the later 400's only had 2. its confusing to say the least.
