7 members (78buckshot, Otto Skorzeny, Hotrod Lincoln, Lightholder's Dad, Dennys28, Wayne67vert, MickeyP),
231
Mod | | | Forums66 Topics128,285 Posts1,058,533 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 2 New Guy | | New Guy Joined: Sep 2009 Posts: 2 | Glad I found you guys. I just picked up a 1957 3100 shortbed. I already had the Camaro subframe, rear end and column (1980 Z28) for this truck. I have no problem doing the subframe work I would just like to see more photos of how you all have done it before I cut. I'd love to see some of the local St. Louis ones in person.
Isn't there a set of frame brackets out there that allow you to hang the Camaro rear and springs with out much modification?
Also, I know the '57 fenders are different than the '55 and '56 but is the actual grille opening the same so you can run a '55 or '56 grille?
Any help would be appreciated. Thanks! New Guy
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Welcome aboard. You would get more responses in the Hi-Po section of the forum. You may also want to run a Search Here is a link I started that my be helpful . I personally do not like clipped vehicles as there is always a chance of a stress crack starting where the two sections are joined. Scott
| | | | | Joined: Oct 2009 Posts: 13 New Guy | | New Guy Joined: Oct 2009 Posts: 13 | If you dont find what you need I have a 49 in the shop with a77 Camaro front clip.Just let me know .
| | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | | | |
