Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Wayne67vert, Phak1), 153 guests, and 4 robots.
Topics128,282
Posts1,058,493
Members48,490
#585247 10/21/2009 3:40 PM
Question for ya.
my truck is a 46 2ton PV 134 1/2 WB
how do i know which engine i have.?
Servant of the Most High God
1946 Chevy 2ton X Fire Dept Tanker truck from Faith, SD
bamabobalex #585258 10/21/2009 4:05 PM
I cant get to the ser# on the block right at the moment but, here's what i do know.
On the cowl tag it says.
HP of ENGINE. 83.5 @ 3000 rpm
bamabobalex #585266 10/21/2009 5:36 PM
I found this casting number. 3835849
Our friends over at inliners say it is a 42-53 216 cid.
This Engine WILL be FOR SALE. i havent heard it run yet but, it does turn over by the starter well.
bamabobalex #585295 10/21/2009 8:05 PM
advertisements should be placed in the Swap Meet
tclederman #585638 10/22/2009 10:14 PM
put a fresh set of acdelco r45's in it, some unleaded in the carb bowl, spun it a few times & she puttered right to life. pumping 15 lbs of old crude at idle. water pump is rattling. a slight chatter of rocker arms (normal), all sounds good.
