4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | So I got a 1/2 ton front axle for my 1 Ton Swap, but I noticed after cleaning all the grease and dirt off it that one of the pads where the U-bolts go have some rust and pitting. Mind you there is at least a inch of metal around the holes still but it looks like it is slightly thinner than it originally was. It is on the same side as the shock mount piece, I do not feel that it is in danger of breaking or becoming fatigue, but is there anything I can do to build up the metal in a sense? or since the shock mount piece will be there it will be sandwiched in there anyway, should I just POR the axle and then let it be?
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | at least a inch of metal around the holes - makes it sound as though there's enough metal, that is, unless it looks as though there was an 1-1/2 originally. but whatever the case, welding and grinding to shape is the way to go. and if it matters, with extra effort on that method, someone would never know the diff | | |
