2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
#584553 10/19/2009 2:33 AM
I am looking to swap a newer rear axle possibly a chevy 10 bolt, does anyone have the width of the stock axle?
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
about 59 inches wheel mount to wheel mount. Don't take my word for it, measure for yourself. The bed is 48.5 inches wide, and the fenders are about 11 inches deep. You can use these measurements in a formula to figure out how wide your rear end needs to be to center the tires in the fenders.
For my 1940 GMC 3/4 ton longbed, I ordered an IMCA modifed f@rd 9 inch that was 61 inches wheel mount to wheel mount. The rear end was about 2 inches wider than stock because I am using wheels that are offset inward 1 inch. In other words I have 16 X 7 rims with 4 inches of backspacing.
