4 members (TexasA&M48Truck, 32Fordpuchoptop, TUTS 59, 1 invisible), 47 guests, and 4 robots.
Topics128,021
Posts1,055,349
Members48,420
#58440 03/29/2006 12:41 AM
Need to know what the timing is supposed to be set on - for a 1978 250ci engine. It has a one barrel carb. Any help would be appreciated.
#58441 03/29/2006 5:03 AM
The 1976 has three different setting 6, 8, 10 depending on trans or ??? Any one of those should be close enough, if it pings set it back a little. The only way to be sure exactly what it is, check the distributor number against the factory shop manual.
Larry
I don't own a vehicle that isn't old enough to drink.
#58442 03/29/2006 6:30 PM
My 250 hooked to a Turbo 350 is set to 6 BTDC. Runs fine
#58443 03/30/2006 1:37 AM
Thanks alot for the response. I checked the timing and it appears to be right. My problem is...I can't get any acceleration. New carb.It backfires thru the carb but only when you try to accelerate. Any suggestions? By the way, it has a turbo 400 tranny.
#58444 03/30/2006 4:31 AM
Sounds like the vacuum advance is bad. Hook up your timing light again check were the it's timed. Pull the vacuum advance hose off and check the timing again it should of moved by 18-24 degrees. If it hasn't moved you need a vacuum advance diaphragm for your distributor number. Should be 24 degrees for the automatic unless GM changed the vac adv from 76 to 78.
btw You did disconnect the vac hose to the distributor to set the timing and the vac hose does have a vacuum on it?
Larry
