2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Am wondering if it would be cheaper for me to "piece together"a disc brake setup?I have a set of Hollander interchange manuals.Instead of going with a "kit"?
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It would probably be cheaper. It will be time consuming to go and scrounge all the parts you need and build the brackets. If you have more time than money, go for it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can buy the bracket kits & sqrounge the rest. If you want to use 6 lug wheels you will need to buy specialty rotors.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | What is the best kit to get if you want to keep your 6 lug wheels? Also, what is the best way to do a power brake booster?
Sorry for hijacking your thread, but I'm doing the same thing as you to the same truck! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What is the best kit to get if you want to keep your 6 lug wheels? Also, what is the best way to do a power brake booster?
Sorry for hijacking your thread, but I'm doing the same thing as you to the same truck! I have used both the CPP kit and the Performance Online kit on '54 GMCs. Both required modification. Both master cylinder brackets had to be cut and re-welded. Some grinding had to be done on the brake brackets on both and on the caliper castings on the Perfomance Online kit. It would be hard to say which kit was best. Here's the story on the CPP kit. It starts at about the middle of the page. The only experience I've had with a kit for a '58 was installing a manual dual cylinder on my '56. I used the CPP bracket. I had to make a nutplate and buy a longer bolt for it. Here's the story on it. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | CCP kits for undercab power brakes only require drilling some holes, moving the ebrake pulley and modifying the ebrake cable attach. All simple. The front disc brake conversion requires very little mod depending on the wheel you have. Don't forget the bearing conversion from ball to roller that they and others sell. Tried to buy these from Classic Truck but no 10% discount on "drop ship". Silly!!!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | CPP? hmmm have a link to them?
Thanks for the info! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Is there a website that I can look up information about "doing"the disc brake upgrademyself?Still not sure if I wouldnt be better off buying a "kit".But I bet the kit wont have instructions.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 58 I'm working on now already has them on it but I am redoing them. The calipers are mid 70's full size & intermidiate cars. I got new ceramic pads & caliper kits. The rotor,s are 11 in. from mid 70's intermidiate. It has a 4 3/4 5 bolt pattern. If you are going to use 5 hole wheels I would get a kit with the brackets, spacers, bolts, & brgs. with spacers & scroung the rest. If you want 6 hole wheels you would probably just buy the whole kit. If you want me to send some photo's I can but it will be Tues. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I have six lugs on my truck.Thanks for the advice.Not in a hurry -so I thought it might be cheaper to just piece it together BUT I dont have enough knowledge.I know Classsic Parts has a 6 lug kit.
| | | | | Joined: Oct 2008 Posts: 8 New Guy | | New Guy Joined: Oct 2008 Posts: 8 | I'm changing out my kingpins at the moment and am taking the front disc route with my '51. I considered just ordering the bracket kit from cpp or classic parts.com, but taking the piecemeal route with my local auto store seems to only save me about $30 including shipping and I'm not sure I included everything that comes with the kit. No doubt I could save more by hitting salvage yards, but brakes are the last thing I would even dare to think about skimping on; let alone getting stuff from mid '70s vehicles. I just bit the bullet and 5 minutes ago purchased a kit on sale with performance online through their ebay store for $279, reg. $349. It seems to be the exact one from cpp, so except for minor mods, it should be a basic bolt on. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As I stated about 5 posts up, the CPP and Performance Online kits are not the same. And yes, expect mods to either one. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | The mods are reworking the brake lines?I think I will opt for a complete kit with master cylinder/power booster that fits in the original location.I I am on a budget-heck who isnt now a days.So I want to get the best for my sweat earned $$.
| | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | The mods are reworking the brake lines?I think I will opt for a complete kit with master cylinder/power booster that fits in the original location.I I am on a budget-heck who isnt now a days.So I want to get the best for my sweat earned $$. *Is also trying to decide the best kit* | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | the complete/convenience route is nice, but i'm going the parts route | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | They all have complete instructions on paper and some have it online. They all sell on EBAY. Be sure to add the shipping to the price, sometimes they come out very close, they play with the shipping costs. Also don't for get when you get the combo, for I think about $650, you need to get the bearings for another $120. And then there is power steering. As far as mods for the undercab brake unit, I described that in my previous post here. Bracket holes, relocate pulley, reline with store bought brake line pieces/fittings at Checker, Ebrake rear lever mods, cut hole in floor (if you want)The best way for filling reservoir, which I did not do, is get the reservoir cap that has hose fittings to a remote reservoir on firewall.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | And then there is power steering - how/why are you relating that? | | |
