| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Was wondering do you need to run a fuel pressure regulator with this carb? If so what would it need to be set for?
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Webers don't want much more than 3 pounds. I'll assume that's also true for the Holly/Weber. Tom Langdon would be the one to ask.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I have run both a single H-W and a pair of them on my 261 with just the mechanical fuel pump (no regulator) with no trouble. I've even run one on a 250 w/o a regulator with the same results. | | |
