1 members (Peggy M), 74 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#582739 10/12/2009 9:46 PM
Well, our '56 3200 is finally on the road! I don't have an owners manual, and am not sure about how to read the stock oil pressure and temperature gauges. The gauges are simply 3 white dots. Where should the needle normally be, and at what point should I get concerned? At what point do I panic? Can anyone advise if the 3 white dots correspond to specific psi/temperature readings?
Thanks!
Stephan
The lens should be marked with 0-60 for the oil pressure, temp should be marked C and H cor Cold and Hot. As far as where the needles should be, when it's warmed up, they should be approximatly at the center dot, perhaps a bit past (to the right). I can't really give a specific on the temp, other than the original equipment thermostat was 160 degrees, so the middle dot is probably roughly that. The center dot on the pressure gauge is 30 psi.
Bill Burmeister
Thanks Longbox55, so far so good.....Oil pressure sits a bit above the centre dot when driving, and sits halfway between the centre and left dots at idle speed when fully warmed up. The project has come along nicely, and I've received great help from the gang on this board!
