7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible),
77
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 8 New Guy | | New Guy Joined: Oct 2009 Posts: 8 | ok guys...I find all kinds of kits to swap 1/2 ton brakes, but nothing for 3/4 tons? I know guys do it, so are they just using the 1/2 ton kits? Also, which is easier..swapping gears out of the rear end on a 4 spd with granny gears or swapping the whole axle out? Currently running a 63 230 w 4 spd granny and am thinking of switching to a 350/350 combo. I'm sure some of you have done it, how bad is it to do? Thanks
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On the brake swap, you would want to consider swapping out to a later front axle. The disk conversion kits for the 1/2 tons are for 2wd trucks, and then the guys that don't use kits are using spindles from later model trucks, which includes the 3/4 tons, too. In the case of the 4x4, the drum brake 4x4 axle is a closed knuckle Spicer 44, which is a kingpin design. The disk brake spindles from the later 4x4s are an open knuckle balljoint design, and do not interchange. As far as the rear axle goes, you can swap out the 3rd member to change the ratio, just like the 2wd trucks can. Gear ratios are pretty much limited to 4.10, 4.56, and 5.14. The 4.10 ration was used in the '68-'72, usually with 350 and automatic, and it was also common with the Camper Special package. If you want a higher ratio, you'll need to swpa the rear axle. Might be best to swap the front and rear at the seame time to have a matched set. Use cautin with 3/4 tons from the '80s, as many of them used the semi-floating rear axle. that design is not as strong as the full floating axle, which would be the suggested axle for a 4x4. You may consider looking at the '77-'86 K30 and '87-'91 V30 for axles. They used the full float 14 bolt in the rar, and the open knuckle kingpin style Dana 60 in the front. Virtually bulletproof axles for 4x4 use.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 8 New Guy | | New Guy Joined: Oct 2009 Posts: 8 | I think I forgot an important piece of info...mine is a 2wd.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Oh. That would make it a C20. K20 is a 4x4. In that case, you can pretty much simply swap out the balljoints to the later ('73-'87) along with the outer tire rod ends and use the steering knuckles from the later truck. You could also swap the entire crossmember and get power steering, too. Try a search on the site for crossmember swap, you should be able to find some more accurate information on doing the swap.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 9 New Guy | | New Guy Joined: Nov 2009 Posts: 9 | Can you use the '73-'87 parts to convert a '62 C20 also? I'm looking for a disc brake upgrade to keep the 8 lug pattern. Will the '73-'87 crossmember bolt into (for the most part) a '62 or is the frame width different?
"Gas money give out in Gurnee" Eddie from Christmas Vacation
1962 C20, currently "Yard Art", working to reverse that.
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I have heard of it being done. I don't know how difficult it is or the frame width issues, all I can say is I have heard of it being done on '60-'62 trucks.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
