0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | For my 63 4x4 sub I would like to know which years turn signal switches will fit. I pulled the wheel to repair the loose play between the 1st and second bowl and checked out the turn signal switch ( its OK for now ) but when I called around the parts guys they are only showing a "repair kit" for my 63 burb which I take to be a cancel cam repair kit if that is what you call it. What years will the whole switch fit?
Thanks in advance as always!!!
EB. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Shee Mar has been making turn switches and parts for over 30 years. They will help you contact them. Here's the link; http://www.shee-mar.com/start.htmlLarry
I don't own a vehicle that isn't old enough to drink. | | |
