| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | whats all needed/ involved in putting HEI dist. in my 65 c20. It has a 250 from a 76-79 car?? ( integral intake manifold)
how much does it cost, i will do all the work myself.
and where do i get it?
Thanks, | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Get a HEI dist, w/all the guts and a dist cap w/the coil which will go in the top of the cap along w/the plug wires. To install is just like replacing the stock point dist. THIS VIDEO should help you even though it is for a V8 w/installing. Cost?? You can find them they on ebay using "chevy 6 distributor" in the search BUT be sure NOT to get a 2.8 or 4.3 V6 dist. they will NOT work, or at your local boneyard or parts house. THIS site may help you. | | | | | Joined: Mar 2009 Posts: 25 Apprentice | | Apprentice Joined: Mar 2009 Posts: 25 | Used HEI distributor $30.00 to $50.00 from ebay.Coils that are in the cap cost a little bit more.
Jimmy | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Make sure you remove the resistor wire for your old coil. with nowhere to go the power can make that wire melt along with all the wires around it and maybe your truck. | | |
