1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#5810 11/17/2003 10:31 PM | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | I have the rear end out of my truck and want to clean it up and paint it. I am wanting to get whatever existing heavy gunk is on it of and out of the iside.I have heard sand blasting = bad. If I take the third member out and set it in a cleaneris that bad? How far apart does all of this need to come? I just want to stop the leaks cleanit up paint it and try it out. What do you guys suggest?
thanks, Sean | | |
#5811 11/17/2003 10:44 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sand blasting on something that thick doesn't hurt anything, as long as you can keep the sand out of the inner workings. That's the problem.
I just cleaned and painted the rear on my 69. First, scrape off all the gunk. Then, power wash it. You can go to the car wash, but don't let the owner catch you! What I did after that was to go over it with stiff brushes and de-greaser, until I could hose it down and not see oil on the water. If you have rust, a solution of muratic acid will make the rust go away, just be sure to neutralize it immediately. I've also used naval jelly (phosphoric acid) but it takes a lot more elbow work, even though it doesn't rust as bad afterwards.
Fred 52 3600 69 C-10
#5812 11/17/2003 10:58 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | I second Fred's opinion here. First, scrape the chunks then use a parts cleaner to get the rest of the grease off. With plenty of work here, you should be able to get a nice painted surface. Sandblasting to bare metal is overkill and not necessary if the components are in tact, sealed and real clean.
On the other hand, you may not see this post as I used the word "bare" while talking about cleaning a rear end! :rolleyes: | | |
