| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | How do I replace the seals/gaskets on 58 GMC truck?two square foam seals came in mail-no instructions.Also how would I adjust the cable so that it works when pulled/pushed. Thanks,Danny | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Great question - both of my vents are rusted shut. I'd like to know where to start. | | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | dtwbcs, I just complete the same project. I should have taken some photos but I didn't.
Disconnect the vent cable and remove vent cover and then the vent door. I then pulled the old foam out of the vent door. The vent door is 2 pieces of sheetmetal sandwiched together. I took a screwdriver and open up the channel that the foam goes back into. Squirt it with a little glass cleaner to make it slick and push it into the channel. Be careful because the new foam is fairly delicate. When you get it all in, lay on the floor and tap lightly around the edges with a hammer to tighten up the metal around the foam. My cable was so rusted I could not get it to open and close smoothly. I bought new replacement cables from Classic Parts. They work silky smooth. Everything works like new now.
Good luck, Hugh 55 2nd | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I took the drivers' side apart.Sanded&primed,painted black.It was in two pieces.Just will bolt it together.Kept a piece of the original gasket,to give the correct spacing.Passenger side I "pried" apart&replaced the gasket.It wouldn't seperate.Primed&painted.Just took alittle studying before I started. Still am not sure how to adjust the cable Danny | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Now all I have to do is adjust the pull cable
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
