Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, Gdads51, 55shaker, 1 invisible), 128 guests, and 2 robots.
Topics128,281
Posts1,058,472
Members48,490
#580624 10/05/2009 1:14 PM
I have a '65 chevy 230 6. I would like to put a 4-barrel intake and carb on it. Can anyone recommend an easy bolt on hassle free set-up (offy,clifford, etc.)Thanks for all the help
Wouldn't be difficult to make one.
OK..... Is there a bolt on adapter from single to 4 barrel out there in aftermarket land? Maybe? Thanks for the reply!!!!
Some Monday morning sarcasm. If you want "hassle free" leave it stock! 4bbl to 1bbl adapter are you serious.
The easiest carb upgrade would be Stovebolts Holly/Weber with a 2bbl to 1bbl adapter. The cost is right too.
The Offy 4bbl manifold is thought to be the best street manifold. You will have to adapt the throttle linkage or replace with a cable. In addition you may have add a heater box under the carb for best performance, if you also have headers.
Larry
I don't own a vehicle that isn't old enough to drink.
Check this site for ideas. www.t6Racing.org
Larry has neat set ups for proper linkage control.
Drew
DrewP #580760 10/05/2009 10:25 PM
With the way gas prices are... I woud opt to keep the 1bbl.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
Actually that might not be correct. The primary on the Holley/Weber is smaller than the stock 1bbl. Then it all depends on how you drive too.
Larry
I like the Offy aluminum manifolds for 2 or 3 1-bbl's...seems more efficient to get the carb(s) closer to the ports. Besides, nothing looks cooler than a row of carbs!
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
the 2 or 3 carb setup does look cooler, but can be a little bit of a chore to get/keep the carbs all set correctly. he said hassle free right? grin
Apprentice
Apprentice
$230.00 for a Offy four barrel intake.
$350.00 for a New Holley 390 CFM carb.
$35.00 thottle linkage parts
It all comes to how much,do you want to spend.
Jimmy
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
LGriffin
"The easiest carb upgrade would be Stovebolts Holly/Weber with a 2bbl to 1bbl adapter. The cost is right too.
Where do you find it ?Is there a link ?
DrewP
At www.t6Racing.org everything is out of stock or "coming soon
#583004 10/13/2009 6:58 PM
I think the quick answer to your original question is no, there is no adapter for 1bbl to 4bbl. Here is a link to the 2bbl h/w carb. I use one on my 250 inline and it works great!
http://www.stoveboltengineco.com/acartpro/product.asp?productid=178
