0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58057 03/20/2006 9:13 AM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | My daughter went to start her 87 yj today. The 4.2L-6 cylinder turned over, but didn't fire. Usual thing first start of the day.. after that just a click of the solenoid and the volt guage jumps. Checked voltage 12+ at battery, into solenoid and, when key is in start position, coming out of the solenoid. Tried putting power straight to starter...nothing. Replaced this 2 month old starter with a brand new one. She turned the key...click, a light orange spark at the battery and nothing. Had to get to work and didn;t have time to check voltages. I will check voltages and probably replace the solenoid tomorrow. Any other suggestions? This thing has the separate Ford solenoid and starter set up. Thanks in advance.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
#58058 03/20/2006 10:01 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | jeepforum.com can probably diagnose the problem in seconds. | | |
#58059 03/20/2006 3:18 PM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | If you saw a spark at the battery, you have a bad connection. Take the terminals off and clean everything until in shines.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#58060 03/20/2006 8:10 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Common problem with those engines is the sensors on the flywheel and bellhousing. Can't remember the name just now but it controls the fuel injection. Without it you get spark but no fuel. You can get a new one and replace them easily. Try your local FLAPS (friendly loca auto parts store)
#58061 03/20/2006 10:14 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Think those are called crank position sensors. Had one go bad on my '89 Cherokee inline and also on my daughter's Wrangler 4 cyl. | | |
#58062 03/20/2006 10:17 PM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Thanks for the replies... No fuel injection.. and nothing more than the clicking of the solenoid. Won't spin the starter... turned the engine over with a wrench, so it didn't suddenly seize. Don't have time today to work on it.. but keep the suggestions coming.
#58063 03/22/2006 7:27 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | My '00 XJ had a failure in either the coolant temperature sensor or the manifold air temperature sensor. Ran like crap until the JeepForum guys got me on the right track. | | |
#58064 03/22/2006 8:09 AM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Found the problem! Poor Ground!! ... Had time this afternoon to look at it. The spark at the battery and talking to one of the mechanics led me to look closer at the cables. All cables were in good shape, but the ground wire at the battery terminal was very slightly loose. I cleaned the connection and retightened it and... Voila.. it started.  Everyone is happy again. While I was mucking around in the engine compartment I also found out why it was idling so rough and would stall occaisonally. Daughter is really happy now. thanks for all the help.. and I'll remember jeepforum for the problems that WILL (not may) happen in the future.
