4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#57970 03/19/2006 2:52 AM
ajc
Offline
Junior Member
Junior Member
i just purchased a 64 c20 with a 1970 chevy 350 engine. there is about 3/4 inch hose coming off the back of the carb not connected to anything. if i put my finger on the end of the hose the engine idle decreases and the engine wants to die. what the heck is this vacuum hose supposed to be connected to?
-anthony
"Send lawyers, guns, and money." W.Zevon
#57971 03/19/2006 3:20 AM
Some early PCV kits had a plate that mounted under the carb for the feed to burn the crank case fumes. Look for a PCV on a valve cover.
Larry
I don't own a vehicle that isn't old enough to drink.
#57972 03/19/2006 3:32 AM
ajc
Offline
Junior Member
Junior Member
thanks larry, but no pcv valve on the valve covers.
#57973 03/19/2006 3:58 AM
3B Offline
Hy ajc, That hose was probably connected to a brake booster at one time, if your not using it it should be plugged and the carb adjusted to run properly with it plugged, otherwise your engine is ingesting unfiltered air through that hose.
#57974 03/19/2006 4:17 AM
ajc
Offline
Junior Member
Junior Member
3b, sorry but i'm a newbie at all this. how should the carb be adjusted if i plug it? would leaving it unplugged affect the way the truck runs. it seems to have a slight miss at above 30mph.
thanks,
-anthony
#57975 03/19/2006 5:10 PM
Riding in the Passing Lane
You should have a pcv system. There must be a place on the valve cover for a pcv valve. If there is get a pcv valve for that engine & a piece of vacuum hose to conect it to the vacuum outlet. Adjust the idle speed screw to a normal idle speed & adjust the idle mixture screw clockwise till the engine slows down a little & back it out to smooth it out.
1972 Chevy c10 Cheyenne Super
#57976 03/19/2006 5:43 PM
ajc
Offline
Junior Member
Junior Member
Thanks for all the replies. I'll give the pcv valve a try today.
-anthony
#57977 03/19/2006 10:21 PM
ajc
Offline
Junior Member
Junior Member
Wrenchbender, ok I plugged the vacuum hose and increaded the idle screw, idles fine now. Now there are two screws on the front of the carb, they seem to be set at the same position do I rotate both for the mixture?
thanks,
-anthony
#57978 03/20/2006 10:54 PM
I don,t know why I was thinking 1 barrel. Yes the 2 screws down low on the carb are idle mixture screws. Adjust them as previously discribed.
