1 members (baldeagle),
61
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Hello fellow 'bolters!!  I have a '57 3100, and the steering box has a lot of play in it. I know they are somewhat adjustable, and I've already tightened it up once, but I have a feeling its time to rebuild or replace. Question #1. Are the Task Force Truck columns all the same? I found one out of '59 with turn signals that might make a nice upgrade, if it interchanges with the 1957 column. Question #2. How involved is rebuild steering column? I might rebuild one before installing it in the truck to make sure its good. What wears out typically, and is it replaceable? Any recommendations for good kits? Thanks guys for "steering" me in the right direction!!  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The later ones were shorter as they went with a dished steering wheel. I think the 57 is the same as the 58-9. Someone pop in & correct me if i'm wrong. They are easy to rebuild. The lower bushing is one part that wears & even the slightest looseness cwill cause a lot of play. The worm brgs are next. The ball nut & gears generally are OK unless someone left it a long time without grease. It is not nessesary to disasemble the ball nut as long as it turns smooth. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Cool! I don't suppose you have the part #s or a source for the new stuff? Should I just go to NAPA and hope they can figure out what I'm looking for? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 57-59 columns are the same, and the turn sig is the same for all 55-59 and a seperate removeable assy .... doubt you'll find anyone at NAPA who knows what you're looking for, you need to have the parts in hand to try to identify
Bill | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | The turn signal is different for the 55 & 56 models. Those years the steering wheel was flat and the turn signal knob and switch were designed accordingly. The 59 should match the 57.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Jmoore, So if I had a 58 steering column with the turn signal switch, I couldn't take that off and put it on a 55.2 column and have it work? | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | It would probably work if you bent the arm so it didn't hit the steering wheel or used the later wheel.
1957 GMC 150
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've had a dozen or more turn signal assemblies from all the 5-9 years and have never found any difference - the lever is identical 55-59, comes straight out of the cup any year, the cancelling plate that goes on the bottom of the wheel is identical 54-59 .... only thing that might happen is yer knuckles might brush the lever if you have a grip on one of the spokes instead of the rim of the wheel  Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I rebuilt mine, if I remember correctly I got the rebuild kit from American Classic (Chevy Duty). I believe the other suppliers such as Jim Carter also carry the kit. It came with directions and was fairly straightforward. | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Thanks for the FYI on the kit at American Classic!! I found it and it looks like it has all the seals, gaskets and bearings. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | The lever is the same. IIRC The 55 & 56 came straight out from the column with the flat steering wheel. The switch mechanism on the later assemblies puts the lever at an angle with the later dished steering wheels.
1957 GMC 150
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not angled on either the 57 I had nor the 58 I'm driving now, which came with the option  don't recall if any of the 60's trucks I've had were angled - your GMC angled? original? Bill | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Angled? Yes. Original? Who knows?
Jeff
1957 GMC 150
