| | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I went to my classic parts store to get a handbrake cable. The sales guy looked under the truck and said that I don't have a stock 59 Apache LWB rearend. He said I have a Dana44. Google brings up sites for Jeeps, Broncos, and Internationals. Were these ever used by the factory on GM or Chev?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Feb 2009 Posts: 49 New Guy | | New Guy Joined: Feb 2009 Posts: 49 | I'd never heard of it being used, myself ... Sounds like somebody wanted a bit of rock-crawler fun if I remember my rock crawler magazines right. Be interesting to see how this goes! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Does you're truck have Positraction? The '59s with Posi used the GMC rearend, which was a Spicer 45. The Spicer 45 is very similar to the 44. The parking brake cables and brake drums are different from the Eaton HO36 rearend that open diff Chevies ran.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | This rearend has been in the truck since I took ownership 10 years ago. How can I tell if it's Positraction?
Any marks I should look for on the punkin?
| | | | | Joined: Feb 2009 Posts: 49 New Guy | | New Guy Joined: Feb 2009 Posts: 49 | LMC has some kind of description, http://www.lmctruck.com/icatalog/ca/full.aspx?Page=77 <-- as seen here. Also, I think the old test of burning out, and is it one strip of rubber or two may apply here yet ... Posi is ... two, I believe. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I have a Dana 44 sitting in my pole building. Mine is a posi with 3.54 gearing. It came out of a 60's Suburban. I don't know how you can tell by just looking at it, if it's a posi or not, but if you take the cover off, or maybe jack up the rear end, and spin one wheel, both should rotate in the same direction. I may be wrong, so you might not want to listen to me. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | My Dana also has a little metal tag that says to use limited slip diff. lube only. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There should be the mentioned tag, or, if you jack up the rear and spin one tire, with the trans in neutral, they'll both spin the same direction. In gear, you shouldn't be able to turn the wheel at all. If it is a factory '59 Posi, it will be a 3.92 gear.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | I have a 1962 GMC Suburban with what appears to be a Dana 44. It also has the tag that reads limited slip diff. Is it a Dana 44? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It should be. In the GMCs, they used the Dana axle instead of the Eatons that the Chevrolets used. For a positive ID, take a look on the front snout of the center cection, just above the pinion. It should have a "44" cast into it. The "44" may also be present on the rear face of the housing, to the left of the cover. Spicer/Dana casts the differential model number on the ceter castings. It may also be stamped on the cover, though that isn't always the case.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | She was a Dana 44 as you described. Thanks LONGBOX55. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
