| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, now I want your opinion about the use of the bed wood stacks. I´m planning to put it,but first I need to know how fix the fence to the angle bed(of course into the hole),but it is only by pressing down? It is pine wood like the floor? It was a options? Thanks, Alfonso | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If you are refering to wooden stake sides on a pickup, yes, pine is ok. Just cut the corner stakes to size and fit them down into the stake pockets. Then you can just bolt the the number of side pieces that you want to use. It'll be pretty strong that way.
Drew
| | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | Is this what you mean? Cut posts to fit, attach boads. More detail. Last detail picture. The front with the two sides tied in together makes for a strong fitment. These boards on my truck are more decorative than strong, a good 1" board would be advisable for heavier hauling. I have seen the heights go as tall as the cab,I suppose for transporting goats, pigs, or some other small farm animal.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Thanks again guys that I was looking for. Alfonso | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you trim the board a little from each side till it fits the stake pocket and also at the same angle as the bed side (if it's 1953 or older) it looks nicer. I also dado out a groove that lets the horizontal boards fit into it which adds a lot of stability. First three photos here are of one done that way. http://s32.photobucket.com/albums/d41/coilover/
Evan
