5 members (Otto Skorzeny, Jay R, TooMany2count, Eisenholtz, Shardean), 59 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#578607 09/28/2009 8:54 PM
Hi guys, now I want your opinion about the use of the bed wood stacks. I´m planning to put it,but first I need to know how fix the fence to the angle bed(of course into the hole),but it is only by pressing down?
It is pine wood like the floor? It was a options?
Alfonso
alfonso #578721 09/29/2009 2:50 AM
If you are refering to wooden stake sides on a pickup, yes, pine is ok. Just cut the corner stakes to size and fit them down into the stake pockets. Then you can just bolt the the number of side pieces that you want to use. It'll be pretty strong that way.
Drew
DrewP #578817 09/29/2009 1:06 PM
ODSS President
ODSS President
Is this what you mean?
Cut posts to fit, attach boads.
More detail.
Last detail picture.
The front with the two sides tied in together makes for a strong fitment. These boards on my truck are more decorative than strong, a good 1" board would be advisable for heavier hauling. I have seen the heights go as tall as the cab,I suppose for transporting goats, pigs, or some other small farm animal.
~ Cosmo
1949 Chevy Half Ton
Cosmo #578991 09/30/2009 2:34 AM
Thanks again guys that I was looking for.
Alfonso
alfonso #579339 10/01/2009 2:39 AM
If you trim the board a little from each side till it fits the stake pocket and also at the same angle as the bed side (if it's 1953 or older) it looks nicer. I also dado out a groove that lets the horizontal boards fit into it which adds a lot of stability. First three photos here are of one done that way. http://s32.photobucket.com/albums/d41/coilover/
Evan
