8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
At the risk of sounding completely ignorant, what's the correct(or simple) way to adjust the valves on a '61 235? I've adjusted valves on a 350 v8 before, using the "1/4-turn-after-noise-is-gone-method". Can the same method be applied here or do I need to adjust them with the engine off. I have the shop manual, but it just gives the gap dimensions for the intake and exhaust valves. It doesn't provide step by step instructions, unless I'm real dense and don't see it.
solid or hydrualic lifter? there is good info on this if you go to the tech tips section at the top of the page.
Ex Hall Monitor
Ex Hall Monitor
Another option is to do a search of this forum. This topic has been discussed at length numerous times.
Thanks guys! I found the info in Tech Tips. FYI, solid lifters. Thanks again for the advice!
